About 35 minutes into Saving Silverman on my first disk...the image starts to shift and studders a bit. At first I thought it was because I encoded to high and put too much on a disk....then i re-encoded at standard bitrates and it still does it...at the same exact part.
Can it be a bad DVD rip? what could be causing the same part to be studering on 2 differently encoded VCDs?
Ok...i think i figured it out. I used VCD Cutter to split both differently encoded files....same studdering happened on both VCDs in the same part.
I decided to split the one mpeg file using TMPGEnc fils splitter. No problem this time with the movie.
I'm wondering how VCD Cutter can be causing this. The VCD Cut movies play fine on my computer but not on my DVD player....but the TMPGEnc cut movies play fine on both. Time to uninstall VCD Cutter.
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 13:07 -
compare movies, find insertions in one movie relative to another movie
By beroal in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2012, 00:11 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2011, 00:16 -
Windows Movie Maker crashes and won't puplish whole movie
By LoveMyslf in forum Video ConversionReplies: 27Last Post: 12th Dec 2009, 23:19 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 12:33
