I've searched the forums and thought I found what I needed but I'm still getting bad discs. I am using dvd decrypter, dvd shrink, and record now dx everything seems to go well but all the files(video & others)on the DVD-R stay seperate and will only play when I use win media player and load all the files in order.
I know I'm doing something wrong but what?
I've burnt 3 of these bad discs so far.
Is there a "complete" tutorial/walkthrough on how to use these 3 programs together?
Any help will be greatly appreciated
Thanx
bornfree
I take it you are backing up your movie collection.........
If so, this is what you need to do :-
Use DVDShrink.
Reduce the size by compressing the files so that you have a complete green bar across the top.
Once you have this back up to Hard Disk.
Once complete, use Nero 6.
In th eWizard, Select no multi session on the top left option. Then go to Video (3rd one down on the left). Click NEW on the right.
Drag all the files that DVDShrink copied to your hard disk into the Video TS folder.
Click burn.
You should finish up with a back of your complete DVD.
If their is region coding on the original - download AnyDVD and install, then use DVDShrink.
Rob -
I'm sorry but all I have to burn with is recordnow dx
can anyone help me with using that program?
Thanx
bornfree -
I can help you out with the latest Nero. I can zip and Email if your connection can deal with this and you have time or burn and send it??
Converting 1080 blu ray backup to play on PS3
By spideygower in forum Newbie / General discussionsReplies: 2Last Post: 20th Jan 2011, 15:37 -
Blu-ray backup won't play in PS3
By DGenerateKane in forum Blu-ray RippingReplies: 40Last Post: 27th May 2010, 01:57 -
How can I play a backup DVD on my PS3?
By ZQ8_Blazer in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2008, 06:08 -
Samsung ht q-100 can't play backup DVD's???
By infoman99 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th Oct 2007, 13:09 -
Is there any standalone device that can play backup DVDs from a HD?
By pwangdel in forum Media Center PC / MediaCentersReplies: 8Last Post: 25th Jun 2007, 20:31
