I downloaded some software from mIRC, it was a .bin file. most of the time you get the cue file with it..... but not this time. Is there any way to still burn this image? T.I.A.
Tim![]()
Living in a 3D world, Playing in a 3D world
Not really, open the file with isobuster and pull the files out that way to your desktop. Or burn it with discjuggler (that doesnt require a cue file) just select "all files" and do it that way. Nero will do it too but you have to set foreign image settings and i dont know much about that.
There are also some software that will create a cue file for you. try yahoo for "cue file maker" or "cue sheet maker" -
QUOTE: "Another way... Convert it to .mpg with VCDgear then burn the .mpg with VCDeasy"
That works, but i didnt say that because he said it was just software, not a movie specifically..I download bin and cue apps all the time.
QUOTE: "Is this really a question for this site?"
Yes, this is "Newbie / General discussions", there are no stupid questions here relating to cd images. -
See.... Moloko_Plus has got my back!! thanks for the help... and no thanks CaseyComb. I did find that you can create your own cue files... and that worked. Google rocks
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
