Hi everyone!![]()
I just bought my dad a dvd-burner and thought I'd burn some avi-files so we could watch some movies on his dvd.
So i got Nero Express Ultra Edition and Nerovision Express and all the mpeg-codecs and stuff, and then discovered that it took about 30 hours(!) for the computer to convert half Lord of the Rings!![]()
Is that normal? Why is it so slow? Are other programs faster?
The computer is 600MHz /256RAM.
Happy to get some help from you guys
/Giuseppe
Yes, and you've answered why too! 600MHz??????Originally Posted by giuseppe
Alright, my dad apologizes for his computer :P
...but say he got 2500MHz, how long would it take then?
/Giuseppe -
This would vary depending on what file type you are converting from and to. My XP2200+ processor system takes about 2 hours to convert an hour of DV avi at 720 x 576 to DVD format mpeg. As a rough guide, I work on twice runtime but if it is stuff that has been editted and has transitions and filters applied, it can take longer.
I recently converted Lord of the Rings i have a athlon 2900 and 512ram took me 11 hours.
it all really depends what options u chose when converting like size and stuff like that. -
Ok...
But are some programs significantly faster than others? For instance, this TempENGC you're talking about...how big is the difference timewise?
Thanks for the help!
/G -
I use CCE 2.5 and depending on the quality of the source, how much I filter, etc, I can 2-pass VBR encode a 2 hour 720x480 capture in 3-4 hours. Even faster if I resize to 352x480.
Batch processing AVI to MP4 (H.264)
By Ahari in forum Newbie / General discussionsReplies: 39Last Post: 10th Apr 2012, 13:52 -
multiple processing, or 1-at-a-time?
By coyote2 in forum EditingReplies: 4Last Post: 15th Oct 2011, 18:52 -
Will this cut my processing time in half?
By jsbenson in forum ComputerReplies: 7Last Post: 17th Oct 2009, 22:45 -
Unanswered questions on processing and compressing DV-AVI
By sd_smoker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 40Last Post: 2nd Jul 2008, 17:31 -
Batch processing .AVI
By R2 in forum Newbie / General discussionsReplies: 2Last Post: 12th Feb 2008, 21:34
