Im desperatlytrying to burn a DVD to play it on my Playstation2.
Can someone tell me what NERO settings to make, so that it funktions on a PS2 Player.
My Burning software is NERO Burning rom 6.0.0.9 and the media i used so far was DVD-R.
I allways get an error message when trying to play it on my PS2.
Thank 4 your help.
Results 1 to 9 of 9
Is this a dvd file you have created with svcd2dvd ? I use ritek printable disks (Princo's are no good) and any backup dvd plays fine in a PS2 either chipped or not, but i still have problems with files converted using svcd2dvd think this is more of a issue of how things are done (fooling the dvd player into thinking its a dvd disk) rather than anything else. Playstations are known to be very picky about dvd's...
Maybe others have better luck.Not bothered by small problems...
Spend a night alone with a mosquito -
I've burned a few Ritek G04 dvd-rs and so far they all work on my cousin's PS2. I don't know what model his PS2 is but I just know they do work. Hope this helps.
What burner do you have? I burned + and- for my granddaughter's PS2 and neither played at all.
I dl'd the bitsetting tool for my LiteOn 411, set the +R to DVD-ROM and it played perfectly.
If you have one of the few ( ? ) that has bitsetting available, try that.
Cheers,
George -
Interesting that as i use a pionoer 105 (-r's only) and burn with nero 5.10.28 and princo's wont run on any kind of PS2 yet do the same film on Riteks and they run fine. This is on both chipped and unchipped playstations as well... 8)Originally Posted by ziggsNot bothered by small problems...
I use Nero Express > DVD > Disc to Disc copy.
That simple.If in doubt, Google it. -
_________________
Ive created the Video files with DVDShrink. The Files VIDEO_TS are created properly but somehow i seem to have the wrong settings to burn in my NERO Burning rom 6.0.0.9
PS2 has a problem to reade the DVD even when i burn it with Nero Express.
There are no problems.........Just sollutions
What is the error msg?
I don't have a PS2 but i know that they don't like DVD-VCDs only DVD-SVCDs. Also you may have some PAL/NTSC issues.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Burn from to DVD but what format to play on tv?
By Claxlast in forum Authoring (DVD)Replies: 5Last Post: 18th Mar 2011, 17:57 -
Can the PS2 play divx avi movies?
By amjad_z4 in forum DVD & Blu-ray PlayersReplies: 30Last Post: 14th Jul 2010, 06:52 -
PAL DVD will burn but not play
By vhsreject in forum Authoring (DVD)Replies: 6Last Post: 5th Sep 2008, 03:07 -
LCD Monitor I can play my PS2 on?
By oroboro in forum DVB / IPTVReplies: 3Last Post: 22nd Apr 2008, 09:54 -
HOW TO BURN Ps2 games MDF/MDS on MAC OSX
By kimkimkimmykim in forum MacReplies: 7Last Post: 2nd Nov 2007, 03:52
