This was so easy in MF2. I have DL the trial version 3.
This is what I have done...
-added a video file
-used the multi trim video feature and created 3 clips, which show up in the bottom panel (cut commerials out)
-go to add/edit chapters...
I don't see any of my 3 clips I created. All I have is one long video file. It gives me the option to select points on the file and add chapters but the reason I created clips was to be able to just drop the clips as chapters - that's how MF2 worked.
What am I missing? If I can't created trimmed clips to use as chapters, then this software is pointless.
Please help. Thanks.
I think what I need is sub menu's. It seems that I was able to create chapters. However, I have one video file which should be the top menu and I would like to add the chapters as sub menus. Does MF3 support this?
Thanks. -
In the all-new Ulead DVD MovieFactory 3.0...
http://www.ulead.com/dmf/trial.htm
...do you see the ADVANCED SETTINGS button below the window?
Click that.
You should see three options:
- ADD TITLE MENU;
- CREATE CHAPTER MENU;
- SHOW THUMBNAIL NUMBER
This fixes the old problem in version 2.0 of having to have a single-thumbnail MAIN menu.
If you *want* sub-menus, then select the option to CREATE CHAPTER MENU.
Jerry Jones
http://www.jonesgroup.net
Originally Posted by Denman007 -
OK - I was going to post a new note about MF 2.0, but then I saw this post
and think it answers my question - though I hope what I'm reading isn't the end-all to my issue...
I use to have MF 1.0, I liked it just fine and it did the trick.... I could create a DVD with a single "menu" that had multiple chapters display when you launched the DVD...
I upgraded to MF 2.0 and it seems (as noted in the post here) that I must have a "single thumbnail" main menu that you must click on to get tothe Chapter menu... is this true with MF 2.0... this kinda sucks... anyway around this (besides upgrading to 3.0) ?Joe Video -
Thanks Jerry for your reply.
I think my confusion was when you only have 1 video file, it appears you cannot have a title AND submenu with chapters(although you can check both features). It's 1 or the other. That's probably not going to be an issue but was confusing trying to set up a few samples.
When I added a second video file, I got the behaviour I expected.
I need to test the capture features tonight. I may also DL VS7 and mess with that a little.
Jerry, 1 more question, as I see you're answering questions here and on Ulead's forum. It appears VS7 has a few more editing features, is it as easy to use as MF3 if I only want to trim clips and burn to DVD?
Thanks.
D -
I'm writing a step-by-step tutorial about how to use the Multi-Trim feature in Ulead DVD MovieFactory 3.0.
I expect to have it finished by sometime tomorrow.
I'll post it here when I'm done.
As for the comparison between DVD MovieFactory 3 and VideoStudio...
VideoStudio 7.01 is primarily an *editor* with authoring capability:
http://www.ulead.com/vs/runme.htm
DVD MovieFactory 3 is primarily an *authoring* application with editing capability:
http://www.ulead.com/dmf/runme.htm
Jerry Jones
http://www.jonesgroup.net -
Ulead DVD MovieFactory 3.0 Multi-Trim tutorial:
http://www.jonesgroup.net/multitrimstepone.htm
Jerry Jones
Chapters no longer work after adding audio to DVD.
By Nagashi in forum DVD RippingReplies: 4Last Post: 25th Jul 2010, 18:27 -
Adding chapters to .pm4 video to burn to dvd ...
By CaptainChaos in forum Authoring (DVD)Replies: 2Last Post: 13th Sep 2009, 06:54 -
Adding chapters in TMPGEnc DVD Author 3 with DivX Authoring?
By T_virus in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 20:53 -
adding chapters to a dvd
By loa909 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 09:02 -
Ulead DVD Movie Factory
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14
