As i am a newbie to all this video stuff and want to learn to do things properly,i would like to know how i install codecs into virtualdub.Sorry if this sounds dumb,but if i don't do it right then i'm not going to learn the right way.Any and all help will be appreciated.
Results 1 to 9 of 9
Virtualdub(and its derivatives) utilizes the codecs that are installed on your system. It doesn't draw from its own pool of codecs. There are numerous codec packs that are available but it would be best if you installed the codecs you want individualy. Which codecs do you want?
It wont work. Leeeeeeeeeching isn't allowedOriginally Posted by teegee420
. You must click on the xvid codec link and on the xvid binaries.
Thanks to teegee420 and baldric.The direct link did work.I will give this a try and see what happens.Again thanks very much.
I changed it, Baldrick. My bad. :P
You're welcome, venlib.
help with virtualdubmod
By losernoob in forum SubtitleReplies: 7Last Post: 12th Sep 2011, 11:23 -
What should I use instead of VirtualDubMod?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 14th Feb 2011, 03:06 -
Need help with VirtualDubMod
By Brakiri in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2010, 06:28 -
Virtualdubmod
By Irolaan in forum Newbie / General discussionsReplies: 0Last Post: 19th Sep 2009, 13:57 -
About VirtualDuBMod
By YairGOW in forum Video ConversionReplies: 4Last Post: 10th Sep 2009, 17:45
