Hi,
I would appreciate advice on the best settings for encoding to MPEG1, using TMPGEnc
SOURCE MATERIAL : MiniDV shot with Sony Mini-DV DCR PC9 .
CAPTURE AND EDITING : Video has been capture using a Pinnacle Studio DV capture card with firewire port, as 720x480 AVI. Editing has been conducted with Pinnacle Studio.
MY GOAL : Have the video burned as MPEG1 on CD-R as part of a multimedia presentation. This will only be run on PC running Windows.
My goal is to have a "normal window" view for video as 384x288. And an option for "full screen" which could be something like 640x480.
QUESTIONS :
A - So, to watch this video exclusively on computer, should I have to deinterlace, even for 384x288 ?
B- What is the maximum video bitrate that can be used, which will not face problems with CD-ROM drive speed capabilities ? have heard that 1200 would be a limit, since beyond that, only the newest CD-ROM drives could read the CD-R without dropping frames or stutering .
I also wouldn't like to raise too much the bitrate, in order to avoid intensive CPU usage, which could cause mid spec computers to play the video kind of jerky or stutering.
C - What do you normally (for MPEG1 encoding) use for :
1 - Aspect ratio, on Video Tab
2 - Field order, on Advanced Tab
3 - Source Aspect Ratio, on Advanced Tab
4 - Video Arrange Method, on Advanced Tab
5 - Deinterlace Method, on Advanced Tab
6 - Clip frame ( do you go from captured 720x480 to final 384x288 with or without clipping the video)
7 - Arrange Setting on Clip Frame, on Advanced Tab
8 - GOP structure
9 - Quantize matrix setting and options enabled
10 - Audio settings on Audio Tab
11 - Stream type on System Tab
Thank's in advance for any help.
Almost 2 weeks and not even 1 reply ...
Ain't no one shooting MiniDV or converting to Mpeg1 ?
MPEG1 custom GOP settings
By sipposa in forum Video ConversionReplies: 8Last Post: 11th Jul 2011, 20:23 -
GOP control in ffMPEG MPEG1 encoding
By Computer Nerd Kev in forum Authoring (VCD/SVCD)Replies: 12Last Post: 4th Jul 2011, 03:52 -
can i truncate mpeg1 video files without re-encoding?
By dullrazor in forum Newbie / General discussionsReplies: 2Last Post: 22nd Nov 2009, 16:47 -
deinterlace miniDVD and miniDV material before (re)encoding to DVD or not?
By Massa in forum Video ConversionReplies: 3Last Post: 2nd Jan 2009, 14:54 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31
