I have tried to convert the audio from an avi file to wav and mp2 but i get no sound from either
I have used TMPGEnc to convert my avi file to m2v and wav and FFMPEG to convert the wav to MP2
I would appreciate any help
I have checked the audio in Goldwave and it is 2 channel
I convert the audio in FFMPEG to MP2 Bitrate 224
Thanx for the help
Closed Thread
try open the avi directly in ffmpeggui and convert to mp2.
Hi Mark,
How did you get on with this:
https://www.videohelp.com/forum/viewtopic.php?p=778346#778346
It may still be that you're audio isn't to the right spec. Failing that, you may not have the codecs to play mp2 or AC3.
Use GSpot or AVICodec to see...
When you say there's no sound, how are you testing it? What error messages (if any) are you getting?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
Converting WAV/MP3 to DVD-compatible sound file
By Erasmus in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2009, 22:41 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 15:11 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 16:10 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
