Hi to all,
I have a philips cdi player and use nero to burn my .mpg files in to vcd's which i then play on my cdi player.
Most of the vcd's i have burned play fine in my cdi player but i do also get the odd one of two films that freez around 5 seconds into the film when they are played on my philips cdi player.
Does any body have any idea as why some of my films freez when played in my cdi player but are ok when played on my PC.
Is there away to re-burn the vcd's, like take the .dat file off the vcd's and do something to it before re-burning it?
Any help would be great,
Thanx in advance in all.
SD DVD Played on Blueray Player
By wulf109 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th Aug 2009, 08:36 -
Phillps 5990 - usb operation
By bobbee25 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 10th Mar 2009, 09:17 -
Why only can played with his player
By newbievideohelp in forum ProgrammingReplies: 2Last Post: 12th Oct 2008, 22:06 -
no audio when played on dvd player
By soccer in forum AudioReplies: 6Last Post: 4th Aug 2007, 18:18 -
Same Codecs but cant be played on the same divx player
By weeleong87 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 12th Jul 2007, 13:06
