Hi all -
I'm a newbie...confused by audio sync.
I'm using the Dazzle DVC 150. I captured mpeg 2 using the DVXCEL utility that comes with the DVC 150. The capture split a 1-hour, 45-minute video into three files, and the audio sync is fine in the captures. However, when I assemble the files and try to burn using ULEAD Movie Factory, the audio sync gets off on the finished DVD.
Any ideas/suggestions?
I don't really like using the DVXCEL or the MoveStar 5 software that came the the DVC 150...but those are the only two programs I've been able to find that will actually recognize the DVC 150 device and allow a capture. Any recommendations on a better program...that will recognize the 150?
Thanks in advance.
I had the same problem using DVD movie factory except with a sony dvcam. I'm using DVDMF version 2. There are updates on uleads website. Make sure these are installed before doing anything else. I drove myself crazy trying to figure this out and it was nothing but uleads software.
A lot of people have audio sync problems, but this is the only one I've had myself.
If anyone else has had any other audio/sync problems , please jump in and be heard.MMMMMMMMMMMMM..........sprinkles -
here is my post from audio forum https://www.videohelp.com/forum/viewtopic.php?t=200112
No program is idiot proof! I can prove it :-) -
I'm running the Dazzle Fusion using Movie Star 5.0 to capture AVI files and then taking the captured video and opening the files in a storyboard in Arc Softs ShowBiz DVD authoring program. I can't install the Arc Soft DVD Complete as it conflicts with Roxio's Easy CD Creator (which I'm not going to uninstall). As a result the program that came with the Dazzle Fusion to complete the DVD authoring will not work. I tried capturing with Arc Softs ShowBiz but I had horrible results with regards to audio/video sync. I've read and tried everything and was getting nowhere. Then just by luck I tried capturing video in Movie Star and then finishing up transitions and titles in ShowBiz. Authored several DVDs and they are absolutely perfect. Only problem I have is that the Dazzle Fusion will only allow me to capture video in AVI files (great quality but large files) Is there a way to capture in other than AVI. Guess I'm going to have to get a 120 or 200 gig hard drive. Let me know what experiences you've had. I am well pleased with the Dazzle Fusion.
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 09:49 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
