I'm about to toss everything out the window. I'm trying to get a dvd to an avi file. I've tried using dvdx and dvd2avi. Here's the problem, with dvd2avi I can get an avi file, but i get no audio.
With dvdx, once I start the conversion, it tells me it'll take about 18 hours!!!! I don't have 18 hours to burn one single dvd. dvd2avi takes about 3 hours. but no audio. I have an athlon xp2000 and 512 megs ram. This doesn't seem right.
Any help????
What are the specifications of your file ?
I'm not sure what specs you are asking for but it's a fairly small file. It's a concert dvd which I was able to fit onto a dvdr with no compression.
When I used dvd2avi I got a 700 meg video file. I dont know how dvdx will turn out since I dont have the patience to wait 18 hours for it.
I guess I basically have two issues that need solving.
1. why am I not getting audio using dvd2avi, and,
2. Why does dvdx take so long? Am I using the wrong codec or something? I've tried cinepac, microsoft, and divx 4.12. -
Does DVD2AVI not output a separate audio file
In the audio menu are you selecting a Track number for it to Demux or decode ?
if so, then you should get an AC3/MPA/WAV file in the same DIR as you AVI, depending on the DVD's original audio format and whether you are demuxing or decoding. Decoding will give a WAV file for sure.
Once you have this audio file you to mux it into your AVI - maybe after re-encoding it if it's a huge WAV file.
Hope this helps.
Multiple AVI is WINAVI being put on DVD in the wrong order
By richco in forum Authoring (DVD)Replies: 7Last Post: 23rd Nov 2009, 06:50 -
What am I doing wrong? AVI to DVD with srt subtitles.
By du2vye in forum ffmpegX general discussionReplies: 8Last Post: 21st Oct 2009, 12:54 -
Wrong image size ratio after AVI to DVD encoding
By video34bgi in forum Video ConversionReplies: 2Last Post: 22nd Jun 2009, 10:45 -
AVI to DVD aspect ratio always wrong
By Focaldesign in forum ffmpegX general discussionReplies: 22Last Post: 26th Jan 2009, 18:18 -
WTF is wrong with these young hollywood stars?... Heath Ledger Dies
By MeDiCo_BrUjO in forum Off topicReplies: 43Last Post: 18th Feb 2008, 16:26
