  1. Hi obviously I'm a newbie on here, and I need some help. I'm using Nero 6 and am trying to copy some concert footage that some-one made a cd with. I've dragged it across via explorer to my hard drive then used Nero 6 to make a dvd video. Most of these dvd's are fine, writing on my Pioneer dvd-A160 at either 2.5 x or 4x. But one of these shows will only copy at 1 times and in so doing will not play on my dvd player. Is it something I'm doing or do I need to alter something.
    Can anyone help? Many thanks
    PEACE!
  2. How many attempts did you make to burn it, could have just been a bad disc.
  3. Hi,
    Are the files in VOB file format?
    If they are, download free prog ifoedit and open the Video_ts.ifo file in there.
    If opens successfully click on button "DVD Play" and see if movie plays.
    (Can try playing movie in PowerDVD or similiar as well)
    There's also a button in ifoedit called "Correct VTS Sectors", hit that and then try burning the film.
    Goto http://users.pandora.be/rudy.stremersch/ for more detailed guide on using ifoedit.
  4. Thanks for the help guys. It' is in a VOB format. The thing is when I copy it and play it with Power DVD , it plays fine. But when I play it on my stand-alone machine it won't play, but all the other concerts will!
    PEACE!
  5. Does the file have the same specs as the others. You can check this in gspot.
    If it's wet, drink it
    My DVD Collection
