Sorry for my poor English
I can't burn over 3 DVD data , at the fourth Nero give a message say that "Could not perform end of disc at once "
If I restart my PC ,I can burn 3 DVDs successfully but when I burn the fourth ,it repeats error
My PC is Pentium 4 1.5 Ghz,248MB RAM ,is it too weak for burning DVD ?
I look forward to hearing anything solution ,please help me
Thank for reading
This is log file
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 12:06:00 PM
ahead WinASPI: File 'J:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 1/16/2004 10:41:24 AM
Nero version: 6.3.0.2 (Nero Express)
Recorder: <DVD DUAL GO-W0404A> Version: 0039 - HA 1 TA 1 - 6.3.0.2
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <ASUS DVD-ROM E616 >Version: Z.0 - HA 1 TA 0 - 6.3.0.2
=== Scsi-Device-Map ===
DiskPeripheral : ST340810A atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST3120022A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : ASUS DVD-ROM E616 atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : DVD DUAL GO-W0404A atapi Port 1 ID 1 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d344prt Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
ASUS DVD-ROM E616 H: CDRom0
DVD DUAL GO-W0404A I: CDRom1
Generic DVD-ROM D: CDRom2
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 39845888 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 247MB (253424kB)
Free physical memory: 84MB (86724kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.1.2004
ISO compilation
11:01:32 AM #1 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
11:01:32 AM #2 Text 0 File Reader.cpp, Line 118
Reader running
11:01:32 AM #3 Text 0 File Writer.cpp, Line 124
Writer DVD DUAL GO-W0404A running
11:01:32 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
11:01:32 AM #5 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
11:01:36 AM #6 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2138703 (475:16.03, 4177MB)
11:01:36 AM #7 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
11:01:36 AM #8 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: DVD DUAL GO-W0404A, Media type: DVD-R
Disc Manufacturer: AN31 -
Disc Application Code: 64, Disc Physical Code: 193
11:01:36 AM #9 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
11:01:36 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2138704 (2138704) = #2138704/475:16.4
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2138704 blocks [DVD DUAL GO-W0404A ]
11:01:37 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [DVD DUAL GO-W0404A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4380065792, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2138704 | lead-out | 1 | 0x00 | 0x41
11:01:38 AM #12 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
11:01:38 AM #13 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
11:01:38 AM #14 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
11:01:38 AM #15 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 2x (2,760 KB/s)
11:01:39 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
11:01:39 AM #17 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 52:53,231 (3173231ms) -> OK
11:01:39 AM #18 Text 0 File DVDR.cpp, Line 1512
Recording mode: Sequential Recording Mode for Multisession
11:01:39 AM #19 Text 0 File Mmc.cpp, Line 19451
Set BUFE: JustLink -> ON
11:01:40 AM #20 Text 0 File DVDR.cpp, Line 1643
Start write address at LBA 0
DVD high compatibility mode: Yes
11:01:40 AM #21 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
11:02:03 AM #22 Text 0 File Cdrdrv.cpp, Line 1277
11:02:03.781 - DVD DUAL GO-W0404A\H1 T1 : Queue again later
11:28:20 AM #23 Text 0 File WriterStatus.cpp, Line 115
<DVD DUAL GO-W0404A > start writing Lead-Out at LBA 2138704 (20A250h), lenght 0 blocks
11:28:20 AM #24 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
11:28:21 AM #25 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was 2138703
11:28:24 AM #26 Phase 133 File dlgbrnst.cpp, Line 1800
Writing short lead-out
11:28:41 AM #27 SCSI -1135 File Cdrdrv.cpp, Line 1171
SCSI Exec, HA 1, TA 1, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
11:28:41 AM #28 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
11:28:41 AM #29 CDR -1135 File ThreadedTransferInterface.cpp, Line 1659
Write error
11:28:41 AM #30 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1659
Could not perform end of Disc-at-once
11:28:41 AM #31 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was -1
11:28:41 AM #32 Text 0 File dlgbrnst.cpp, Line 1658
11:28:41 AM #33 Text 0 File dlgbrnst.cpp, Line 1658
11:28:41 AM #34 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 2x (2,760 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 9/10/1999 12:06:00 PM
File 'Drivers\PXHELP20.SYS': Ver=2.02.60a, size=17232 bytes, created 8/27/2003 2:02:00 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 1:27:50 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Closed Thread
One topic is ENOUGH.
https://www.videohelp.com/forum/viewtopic.php?t=200119&highlight=
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 12:40 -
Why I get a data disc every time when I burn BD-5 ?
By mahogany in forum Authoring (Blu-ray)Replies: 7Last Post: 6th Dec 2009, 04:10 -
How to burn DVD data with Nero 7?
By Kakui in forum Newbie / General discussionsReplies: 5Last Post: 28th Oct 2007, 17:00 -
How Do I Burn A DVD Data Disc ?
By vidgo11 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2007, 13:15 -
Nero 7 data verification failed....?
By LoneWolf1038 in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 09:06
