I got this message burning a data DVDR, but the disc works fine, as a complete noob to the scene can anyone explain what the error means and why does the disc still work ok?
Here are the nero logs:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.56, size=163910 bytes, created 02/04/2003 07:13:44
Nero version: 6.0.0.0 (Nero Express)
Recorder: <ATAPI DVD RW 8XMax> Version: 120D - HA 1 TA 0 - 6.0.0.0
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <HL-DT-ST DVD-ROM GDR8161B>Version: 0100 - HA 0 TA 0 - 6.0.0.0
Adapter driver: <atapi> HA 0
=== Scsi-Device-Map ===
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8161B atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD800JB-00CRA1 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : ATAPI DVD RW 8XMax atapi Port 1 ID 0 DMA: On
CdRomPeripheral : Generic STEALTH DVD st3wolf Port 2 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523764kB)
Free physical memory: 41MB (42308kB)
Memory in use : 91 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.1.2004
ISO compilation
10:00:07 #1 Text 0 File Isodoc.cpp, Line 5451
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
10:00:08 #2 Text 0 File Reader.cpp, Line 118
Reader running
10:00:08 #3 Text 0 File Writer.cpp, Line 127
Writer ATAPI DVD RW 8XMax running
10:00:08 #4 ISO9660GEN -11 File geniso.cpp, Line 3814
First writeable address = 0 (0x00000000)
10:00:38 #5 Text 0 File Burncd.cpp, Line 3081
Turn on Disc-at-once, using DVD media
10:00:39 #6 Text 0 File DlgWaitCD.cpp, Line 224
Last possible write address on media: 2297887 (510:38.37)
Last address to be written: 2254751 (501:03.26)
10:00:39 #7 Text 0 File DlgWaitCD.cpp, Line 229
Write in overburning mode: FALSE
10:00:39 #8 Text 0 File DlgWaitCD.cpp, Line 1688
Recorder: ATAPI DVD RW 8XMax, Media type: DVD-R
Disc Manufacturer: RITEKG - 04
Disc Application Code: 64, Disc Physical Code: 193
10:00:39 #9 Text 0 File ThreadedTransferInterface.cpp, Line 757
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2254752 (2254752) = #2254752/501:3.27
relocatable, CD pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2254752 blocks [ATAPI DVD RW 8XMax ]
10:00:39 #10 Text 0 File Burncd.cpp, Line 3318
Recorder and media-info
Burning to ATAPI DVD RW 8XMax on a DVD-R media
10:00:39 #11 Text 0 File ThreadedTransferInterface.cpp, Line 910
Prepare recorder ATAPI DVD RW 8XMax for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 323072000
10:00:39 #12 Phase 24 File dlgbrnst.cpp, Line 1818
Caching of files started
10:02:57 #13 Phase 25 File dlgbrnst.cpp, Line 1818
Caching of files completed
10:02:57 #14 Phase 36 File dlgbrnst.cpp, Line 1818
Burn process started at 4x (5,520 KB/s)
10:02:57 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2104
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
10:02:57 #16 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 13:58,952 (838952ms) -> OK
10:02:57 #17 Text 0 File DVDR.cpp, Line 1407
Recording mode: Sequential Recording Mode
10:02:57 #18 Text 0 File Mmc.cpp, Line 18119
Set BUFE: Seamless Link -> ON
10:02:57 #19 Text 0 File DVDR.cpp, Line 1522
Start write address at LBA 0
DVD high compatibility mode: Yes
10:02:57 #20 Text 0 File Cdrdrv.cpp, Line 7827
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
10:16:46 #21 SCSI -1039 File Cdrdrv.cpp, Line 1361
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04A70000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x2A 0x00 0x00 0x20 0xDA 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x09 0x01
10:16:46 #22 CDR -1039 File Writer.cpp, Line 335
Focus or tracking error
10:16:46 #23 Text 0 File ThreadedTransfer.cpp, Line 227
all writers idle, stopping conversion
10:16:46 #24 Text 0 File ThreadedTransfer.cpp, Line 221
conversion idle, stopping reader
10:16:46 #25 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 0:00,000 (0ms) -> OK
10:16:46 #26 Text 0 File dlgbrnst.cpp, Line 1678
10:16:46 #27 Phase 38 File dlgbrnst.cpp, Line 1818
Burn process failed at 4x (5,520 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 00:27:50 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Regards
pap_1 -
i don't know if this is a legal number or not but are you sharing your registration number to the world
upgrade nero this version was c***
new ver . 6.0.2.3.
Optimal tracking for video != optimal tracking for audio
By miamicanes in forum RestorationReplies: 4Last Post: 16th Oct 2014, 12:52 -
Nero CD/DVD Speed (4.7.7.5) -Error
By bluemoss in forum DVD & Blu-ray WritersReplies: 14Last Post: 12th Jan 2012, 00:08 -
Error, after burning a dvd with nero
By Remyisme in forum Newbie / General discussionsReplies: 13Last Post: 27th Sep 2008, 03:11 -
DVD User Tracking
By Kojak02 in forum Authoring (DVD)Replies: 4Last Post: 28th Sep 2007, 12:02 -
Fixing a DVD recorder by re-aligning the laser/lense focus?
By D'oh! in forum DVD & Blu-ray RecordersReplies: 14Last Post: 27th May 2007, 23:14
