Here is what I am doing. I have a Terrapin CD video Recorder where I burn to CD a VCD dat file. I then take that file into VCD gear and convert it to a MPEG file.
Now the problem I have on my freinds computer not mine (im actually able to do this without a problem) is that when I go to edit the mpeg file in Ifilm edit there is a error message. I had him download the most current version of windows media player and direct x and still no luck. He is on windows 98 operating system. Any suggestions would be great
Mark
MAbbatange@aol.com
Ifilm edit is a real buggy editor i just today used my filx and it worked great, but i got an mpeg output not vcd, but i'm pretty sure it a setting i didn't change
"A good song should make you wanna tap your foot and get with your girl. A great song should destroy cops and set fire to the suburbs. I'm only interested in writing great songs." Tom Morello in Alternative Press -
On 2001-10-17 22:49:07, spiderman2k1 wrote:
you want to change it back to mpeg use tmpg go to edit and Muliplex
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
What do you mean change back to mpeg and use TMPG and what is muliplex -
You did not mention, what is the exact problem. What are you trying to do? Which error message have you got?
Need help authoring DVD from VCD mpeg files with dual audio..
By siratfus in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2010, 05:31 -
Need mpeg-1 to VCD tool that splits
By anadiner in forum Authoring (VCD/SVCD)Replies: 14Last Post: 4th Dec 2009, 05:24 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 23:55 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 17:28 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25
