Just got a JVC HR-S9800U and I'm starting to play with Capturing VHS Home Movies. Got a question about Tracking. The Deck has a feature called automatic tracking ... which says the deck will "automatically adjust the tracking condition" ... and right under it in the docs is talks about "manual adjustment" .... question is .... do I just always leave it in "auto", will that be enough to provide the best quality picture/sound ... or do I put in a tape, go to manual, get the best signal, and then kick it into auto?
MACKY
Let it do it's own thing. Only when it gives trouble should you try to manually track it, which is not often.
Where did you buy the VCR? I have looked all over the net and can't seem to locate a single site that has one for sale.
If you want a new one, try these
http://www.xkms.org/Consumer-Direct-Warehouse-2/JVC-HRS9800U-Super-VHS-HiFi-Stereo-VCR...th-4MB-DNR.htm
http://www.focususa.com/showpage.asp?categoryid=15&category=electronics&subcategory=vc...oduct_info.htm
Just go to google.com and search on "JVC HR-S9800U"
MACKY
Optimal tracking for video != optimal tracking for audio
By miamicanes in forum RestorationReplies: 4Last Post: 16th Oct 2014, 11:52 -
VHS Capture and tracking issues
By nonsuijuris in forum Newbie / General discussionsReplies: 5Last Post: 29th Dec 2011, 15:10 -
Tracking problem with JVC camcorder.
By The-Geek in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2010, 11:23 -
JVC HR-S9800U TBC question
By moondogger in forum Capturing and VCRReplies: 10Last Post: 4th Aug 2009, 21:14 -
JVC HR-S9800U slowing down going into slow mow while playing tape
By deuce8pro in forum RestorationReplies: 3Last Post: 19th Mar 2009, 16:27
