hey sup all. i am new to this dvd burnin scene. i have movies on my pc that i want to burn of onto a dvd disc. for example, i have a movie that is 699 mb in size. but when i go to my movie program to burn it off, Ulead DVD MovieFactory 2 SE, it says that it is 6.0 gigabytes. I tried usin dvd shrink but it does not accept that file type because my movies are an .avi file extension. how can i get this down in size? my movies are good quality but i dont think that has anything to do with it. any suggestion or questions that i can answer to help u help me, post it plzzzzzzzzzz. thanks a lot![]()
Welcome on board!
You do have some reading to do. This place is filled with articles and howtos on video conversion from any format to any format, so just to get started, what's important at this stage (for you) is to determine the from format (as DVD is your to format). Then find the correct guides for this kind of conversion, try them out (most involve freeware applications). If you get stuck on a step, just ask.
/Mats -
ok. well i saw that some of u were talkin about dvd shrink. the problem is that rite now, my file format is .avi extensions. i need to get it into a format that dvd shrink will accept or i need another program that can shrink my videos in the.avi format so i can burn it onto a dvd disc. thanks
/Mats -
https://www.videohelp.com/convert
Go there and in the first pull down select avi -> dvd, read the guides here.
.ts demux tool
By geohei in forum Video ConversionReplies: 7Last Post: 15th Feb 2011, 08:45 -
Best tool for HD conversion
By carlmart in forum Video ConversionReplies: 27Last Post: 6th Feb 2011, 11:28 -
Is there any tool for me??
By kemcel in forum Video Streaming DownloadingReplies: 1Last Post: 9th Jul 2008, 23:16 -
Chapter Tool?
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2007, 09:55 -
Which tool ?
By NICEBUD in forum Authoring (DVD)Replies: 7Last Post: 17th Jul 2007, 14:06
