I have an audigy 2 platinum card and was wondering if its possible to capture 5.1 sound from like tv shows or video from a minidv camera.
I have an optical input port on the audigy, so that may help.
Do I need some hardware like home theater system and output the audio to the input of the audigy card to get 5.1 sound?
Be nice to capture 5.1 audio and make a dvd with 5.1 audio, lol.
Don't know if this makes sense, but I don't know.
To capture 5.1 you need 5 separate sources of audio that go to 5 mikes or inputs.
The least you can do is emulate 5.1 sound as you can already do with most Dolby Digital receivers that have DTS:NEO6 or Dolby Pro Logic II, using any two channel source.
From what you're suggesting it sounds pretty useless to encode 6 seperate channels that aren't really discrete. It's a waste of space.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Need Help Encoding: Surround Sound Goes Away
By antiwebbite in forum AudioReplies: 3Last Post: 9th Jun 2010, 18:48 -
ConvertXToDVD 3.0 Surround Sound?
By chicken32 in forum Video ConversionReplies: 1Last Post: 3rd May 2008, 01:24 -
Surround Sound Separate
By kwalitykontrol in forum AudioReplies: 1Last Post: 31st Mar 2008, 23:01 -
5.1 Surround Sound on DVD
By Adhishyajnik in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:57
