Hi,
I recently converted a div-x I had to PAL from NTSC. The audio and the video are in sync but the subtitles are running on the 23.976 FPS and not 25 FPS. So obviously the subtitles are out of sync and I was wondering how I can convert the fps on the subtitles to make it sync with the audio and visual. I've been reading around the forums about using AviSynth to do it. But I have no idea how to use this program even after looking at guides and such. I now your ment to fiddle around with the scripting but I have no idea how to do it. If someone could run me through step by step I'm sure I can fix the subtitles problem. If there is another way I would much prefer to do it via a easy path. Any help would be much appreciated.
I'm a complete newb when it comes to scripting.
If the subs are text based, You can change the "frame rate" of the subs using Subtitle Studio. (I gather you changed the AVI frame rate by just slowing it down from 25 to 23.976 fps.) If the text subs is time based, this conversion is necessary. If it's frame based, it's not - it should work anyway.
/Mats
How to Sync subtitles from dvd PAL to MKV 23,976.
By axl70 in forum SubtitleReplies: 7Last Post: 15th May 2015, 07:38 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
Subtitles and NTSC -> PAL Video Conversion ?
By shotokan101 in forum SubtitleReplies: 14Last Post: 5th Jan 2009, 20:39 -
Subtitles not added during conversion of Pal to NTSC 2 avis with 2 sup file
By unity860 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 3rd Apr 2008, 06:54
