any1 knws what program i have to used to umcompress file with the extension .ape?
Monkey's Audio Lossless Audio Compression Format
Hex: 4D 41 43 20
ASCII: MAC
winamp has a plug in to play it and use TrID - File Identifier to make sure that is really what it is ..
TrID - File Identifier (supports 932 file formats)
http://mark0.ngi.it/soft-trid-e.html"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
file extension library:
FILExt, the file extension source
Welcome to FILExt, the file extension source. FILExt is a detailed database of file extensions and programs that use them
http://www.filext.com/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How to burn or extract some CUE or APE files?
By diets in forum AudioReplies: 3Last Post: 21st Jan 2010, 11:43 -
.flac/.ape To MP3 | I want the Best Result ...
By Benygh in forum AudioReplies: 7Last Post: 12th Dec 2009, 11:12 -
.ape format how to convert to mp3?
By sumeshkri in forum AudioReplies: 5Last Post: 30th Sep 2008, 23:16 -
Problem with APE file
By Gregg in forum AudioReplies: 1Last Post: 3rd Sep 2008, 07:30 -
Cutting avi's with APE 3?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 13:35
