I have a bunch of clips i want to convert to MPEG-2 and then burn them to DVD. I couldnt use tmpgenc becuase I use quicktime 6.5 PRO, so what i did was I used CCE SP, which gave me seperate output files (mpv, mpa) then i used Tmpgenc to multiplex them together to use to burn.
Heres my beef.
When i convert the quicktime MOV files to mpa/mpv, I get CRAZY interlaced footage, really bad stuff on my fast motion scenes. When i burn them and play on my DVD player, the footage is really hard on the eyes, flashy and Just not right. How can i fix this?
How can i make the converted MOV look as smooth as the original MOV??
Programs at my disposal:
Adobe Premeire Pro
CCE (Cinema Craft Encoder) SP 2.67.00.23
Tmpgenc 2.58
Vegas Video
DVD Architect 1.0
Adobe Encore DVD
Anything else, im sure i could get
just drop them into vegas and set vegas to match input type (or whatever you want) and render to dvd format .... it will be great quality ..
Uncompressed AVI to Quicktime H264
By Simmons in forum Video ConversionReplies: 7Last Post: 3rd Aug 2011, 20:15 -
quicktime plug in for 10 bit (4:2:2) Uncompressed
By privor in forum MacReplies: 1Last Post: 24th Nov 2008, 12:29 -
how to make ffmpeg recognize an uncompressed quicktime source file?
By eighth in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 15:09 -
Uncompressed quicktime to flv conversion
By Ian J Richards in forum ffmpegX general discussionReplies: 6Last Post: 6th Nov 2007, 02:21 -
Error on Uncompressed 10-bit 4:2:2 1920x1080 QUICKTIME to -> MPG
By peejeedee in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2007, 20:04
