  1. it keeps riping in another language pleassssse help!!!!
    Feb 2001
    Berlin, Germany
    what?
  3. Your problem is that the DVD u r trying to rip has other language set as track 1. In DVD2AVI, go to Audio menu --> Track number --> set to 2 or 3, depending where the english track is. (With most DVDs track1 is English, but on some it isn't) Good Luck!!
  4. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    If you are using smartripper to rip, then click on stream processing and check which track has the language you want. The next step is as Alexb descibed.
    The Dutchman
