Is there a program out there that can smooth out video lines like the Video Soap feature in ATI MMC 8.x? If so, would I have to record it in AVI then apply it, do it at capture time, or could I apply it to an already finished MPEG and create a new smoothed-out MPEG? I can't use MMC 8.8, 'cos I have a TV Wonder card instead of a Radeon and it gives me serious audio synch issues no matter what I do, while 7.9 works perfect.
Results 1 to 12 of 12
You cannot apply noise reduction to a mpeg file without having to decode and re-encode the file. Now, a program like TMPGEnc can read a mpeg-2 file (with a mpeg-2 reader installed) where you can apply noise reduction and then encode it to mpeg-2 again. If this is your only choice, record with the highest bit rate mpeg-2 you can do. The better option is to record AVI with a lossless (or near lossless) codec and then apply the noise reduction filter before you encode to mpeg-2. But this requires a fast PC with lots of hard drive space...
Is there one that can do this in mpeg-1? Isn't mpeg-1 better quality?Originally Posted by skittelsen
No, mpeg-1 is used for low quality video like VCD and non-interlaced DVD video. Mpeg-2 is used for high quality video and is the standard for DVD.
MPEG is a type of compression based on pixels.
MPEG 2 compression is based on lines, and supports 2pass VBRShDwScLaN -
Uhhh, no. MPEG-2 is an extension of MPEG-1, allowing for greater bitrates, interlace, greater resolutions, and several other functions.Originally Posted by shdwsclan
They are digital, hence based on pixels. All digital is based on pixels.Want my help? Ask here! (not via PM!)
You might try MainConcept MPEG Encoder. I tried V1.04 to capture MPEG2 with and it does pretty good.
Just a though. Good luck. -
[quote="bottle-necked"]
Is there a guide on how to use it to capture? I keep getting "Start Capture" failed even though the video is showing in the program.You might try MainConcept MPEG Encoder. I tried V1.04 to capture MPEG2 with and it does pretty good.
I'm sure there are others with better recommendations on that program than me. I've only tried it a few times, I'm no expert by far.
Here's what I remember ok.
You must select audio/video input devices.....
You must set a capture filename and location.....
You must select a framerate, size, and codec....
(Or the program will give you that error message)
I think I just went through all the menu tabs and looked it over. I had like 29.970, 720x480, YUY2, Line-in, 48k, etc. The codec compression tab I do remember to used MainConcept MPEG Encoder. Configure it and setup like field order A, choose NTSC DVD template, and note where the quality slider is. This slider is very touchy I remember. To high a setting and you video might come out jerky. (mine did). I went in there the first time and set it wide open and although the video quality was first rate, it jerked. I finally turned it back down to about default level and everything was fine. Watch your CPU load and you can find the cut off point pretty easily. I think I wound up with like 35% quality level, I don't remember, running around 50% CPU load average, peaks to say 65%. Wide open it was peaking to 80% or something stupid like that. Jerky
Good program but a little expensive. Worth a try. You'll like it I think.
Good luck.
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 17:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 03:14 -
encoding mpeg4 with ati MMC results in green video
By toomanyblastedbits in forum Capturing and VCRReplies: 1Last Post: 6th Oct 2008, 01:39 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 20:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 22nd May 2007, 23:44
