TV which doesn't appear if the video is played on the computer (via the DVD player). It's the bright areas of the video (e.g., foreheads) that are most noticably smeared.
This is a capture question because I created a test disk that has the same trailer that was captured in different ways (off a tape that needed TBC).
The versions that do have smear were captured via a composite connection without time-base correction.
The versions that don't have smear were captured via an s-video connection with time-base correction.
I'm assuming the reason some of the clips aren't smearing is because of the TBC. But why doesn't this appear on the video when played on the DVD player connected to the computer? I know computer monitors are progressive and TV's are interlaced but how does that result in such a marked difference in playback?
TIA
Thats what happens when using composite video inputs IMO. Only way around it assuming you don't have s-video outputs is to use a TBC that has a "Sharpness" adjustment which will help define the areas around faces and such.
I just double checked and I think you're right. One of the versions was via composite connections WITH the TBC on and it also has the smear (but to a lesser extent than the versions captured via composite connections that have the TBC off). Funny, I thought it was the TBC making the difference.Originally Posted by Bob W
Thanks!
Panasonic AG-1980 giving a ghostly smear with TBC on. Less noticeable w/out
By ruehl84 in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2012, 12:04 -
how do I know if an avi can be played on a dvd
By flannob in forum Newbie / General discussionsReplies: 4Last Post: 9th Aug 2010, 13:33 -
UK DVD's played in US
By jack209 in forum Newbie / General discussionsReplies: 11Last Post: 24th Oct 2009, 17:34 -
burned DVD can't be played
By linda.0p in forum DVD RippingReplies: 2Last Post: 19th Sep 2008, 14:18 -
Dvd jumps when played
By Radox The Green in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 14:56
