Hi, Newbie here, hope someone can help
I have been using recordnow max for about 3 months, Lately tho it stopped finalising the dvd-r discs, this happened about 4 times but now the software wont even open up. As soon as i start the prog the CPU usage hits 100% and the prog freezes, tried the usual, uninstall, reinstall, system restore but i still cant run the software. Swithed to Nero 5.5.10 and find this too wont finalize the dvd-r. Also having problems finalizing using clone dvd. The media i use (bulkpaq) has given me no problems before. The only next step I can think of is to reinstall windows xp, but as the dvd-r wont finalize, the pc does not read the disc, therefor if i go down this road i have a lot of data that will be lost.![]()
maybe thier is somthing wrong with your burner not the program...i also suggest tryin different media..you might have had no porblem with the media your using before becuase a different manufactuer made them and now the current one u have is prolly made from a different manufactuer which your burner doesnt like...i suggest trin different name brand media if that still doesnt work..try to look at your burner
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 13:53 -
Mix Max Player Help
By Empty_Space in forum Newbie / General discussionsReplies: 26Last Post: 14th Mar 2012, 18:18 -
Max Mp4 player
By drrino in forum Portable VideoReplies: 1Last Post: 28th Feb 2012, 00:04 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
Max I Frames on DVDs
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2008, 18:19
