I have a DVD with only the DTS audio track left. Can i somehow play it on my dvd, which have a DTS decoder in it (panasonic dmr e100).
All i want is a regular stereo output to my tv.
have you tried putting the dvd IN your player and see (hear) if you have sound ?
it may just be the best test .....
or what happened to the ac3 track on your original dvd? ... use that instead ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
That probably won't work. I don't know of any DVD player that will down mix DTS to stereo. The ones with built in DTS decoders pass the audio thru to a 5.1 analog input on a receiver. You might get the front channels thru the stereo outputs, but the center, sub, and rear channels would be lost. The DVD spec requires a Dolby Digital, MPEG, or LPCM audio file to be present. DTS is supported by the DVD spec, but it's not required. You may be in luck if you have a dvd rom drive. Power DVD XP will decode DTS and mix down to stereo on a PC. You could then run the line out of the sound card into the TV.
How to play DTS file
By hungledink in forum AudioReplies: 4Last Post: 19th Nov 2010, 20:14 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 13:10 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 09:40 -
My device DVD can not play DTS
By HoanAkido in forum AudioReplies: 0Last Post: 9th Jul 2008, 23:35 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 07:12
