I am wanting to go to install NTFS but i have a worry. i have 2 hardrives with 4 partions total. Do i need to make both hardrives and all partions NTFS? Will i be able to use the entire hardrive and see all the partions if i just make my c drive NTFS? I know this question might be stupid but i don't want to make a mistake. thanks for any info you can give me.
Well first off, i assume you will be using NT, 2000, or XP.
You can make whatever partition you want NTFS. You will see all partitions if you are using one of the above OS'
You will not be able to see that partition in win 95/98.
NT/2000/XP will also see FAT16 & FAT32 partitions too, so If you just wanted your C: drive as NTFS that would be fine - it would see the others, too.
<font size=-1>[ This Message was edited by: mole on 2001-10-17 21:16:38 ]</font> -
Thanks, i appreciate it. yes i am using w2k so i should be good to go. thank you again
That is not entirely correct. Without a special addon driver (payware), NT 4.0 CANNOT use FAT 32 partitions. And, if memory serves, it cannot even see them. 2000/XP yes. NT No.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
you could very well be right - i'm not too sure about NT4
maybe there is a service pack?
Oh dear. This calls for a very special blend of psychology ... and EXTREME VIOLENCE.
Confirmed - NT4 won't see FAT partitions. You need 3rd party software.
/\/\ars /\/\ayhem
flv convertions your help much appreciated!
By rotuts in forum MacReplies: 2Last Post: 12th Sep 2011, 09:22 -
Time to get a new PC-advise appreciated
By victoriabears in forum ComputerReplies: 23Last Post: 23rd May 2010, 13:20 -
BSOD, help would be appreciated.
By chipsndukes in forum ComputerReplies: 11Last Post: 27th May 2009, 20:06 -
Question about portable drives, FAT32 and NTSF
By jtrinc in forum Portable VideoReplies: 6Last Post: 24th Nov 2008, 20:24 -
question about where bad hard drive disk sector info is stored
By jimdagys in forum ComputerReplies: 1Last Post: 20th Apr 2008, 16:24
