Well I connected my gamecube to my capture card through composotive in. The picture was there but jumbled up, I found out this only happens if you select 60hz mode, 50hz mode works fine. One of my games is 60Hz mode only, I was wondering if there were any options I could change to get it to display properly.
Oh and the gamecube and game are PAL so this is definitely something to do with the Hz settings.
PAL runs at 50 Hz so that is why it is jumbled at 60 Hz. If the game giving you problems is PAL though, how can it run at 60 Hz?
No idea, it baffled me too. It's defenitely PAL though on the box it says it is and a gamecube wont load other region discs without a device called a freeloader. I can load mine up fine without this. Anyway back to the original question are there any options I can change to get it too display properly.
What console game system do you own?
By johns0 in forum PollsReplies: 31Last Post: 14th Mar 2012, 16:31 -
Recording Virtual Console Games with a Hauppauge HD PVR
By GamerSherlock in forum Newbie / General discussionsReplies: 0Last Post: 30th Dec 2011, 06:17 -
Console Recording Setup. Need more help!
By s3r19lk1ll3r in forum Capturing and VCRReplies: 3Last Post: 6th Nov 2010, 22:34 -
Console Capture Card
By YouTrickster in forum Capturing and VCRReplies: 0Last Post: 21st Jun 2010, 12:13 -
Console TV Tuner questions
By darktower in forum Capturing and VCRReplies: 0Last Post: 3rd Mar 2008, 10:26
