I have some MPEG - 4 vidoes that I want to put onto a CD-R and play in my DVD player.
What (free?) software can I use to convert the video/audio of the MPEG - 4's?
Either directly in to the VCD format
Or into some other format that then can be turn into a VCD
Ensign
Well, the easiest way to do this is use Nero to create a VCD. Drag the AVI files into the project and Nero will recode them for you.
Try that for starters.
If you don't really like the quality, then you can use Tmpgenc to recode the AVI into MPEG-1 (VCD) to add into a Nero VCD project. Several guides in the forum can help you in using Tmpgenc to create a VCD video.The more I learn, the more I come to realize how little it is I know. -
before you can convert it, you need to be able to play it.
Can you play it.
Can virtualdub open it? -
I donwloaded the quicktime plug in
It works
Now I can put this MPEG-4 onto a VCD and kid one of my friends on how the world (or in this case GM) thought of itself in the year of his birth .
1961
Converting audio in mpeg-4 video file to mp3?
By lazopper in forum AudioReplies: 2Last Post: 21st Aug 2011, 06:27 -
Converting Video TS into a basic AVI or MPEG
By nadizo in forum Video ConversionReplies: 6Last Post: 3rd Sep 2009, 01:41 -
Audio & video sometimes desynchronized while converting DV to MPEG
By kb1985 in forum Newbie / General discussionsReplies: 0Last Post: 19th Oct 2008, 18:02 -
converting .rm to mpeg, avi using eo video problem!!
By convertme in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2008, 01:37 -
Converting .pvr video files to MPEG or AVI
By Barry1929 in forum DVB / IPTVReplies: 0Last Post: 20th Sep 2007, 20:10
