Just wondering if a Sony DRU-510A plays Region 2 DVD's. I've searched everything and can't find out if it does.
**NOTE: The Sony is also a burner.
Out the box it won't have a region set. You get a couple of goes at changing it before it becomes permanent.
Since you don't say where you live, I'll assume you fall into the region 1 category, in which case you might want to consider:
Hacked firmware
A seperate DVD-ROM drive (my preference) with region free firmware
Backing up all your region 2 discs and removing the region coding
Don't forget the PAL / NTSC issue if you're in the NTSC world. -
or go to the Links section on the left and find and download a copy of DVD Region Free.
Incidentally, why do so many people not bother to fill in their details? It helps an enormous amount to answer a question if you know where somebody is, or, if it is a technical question, what the spec of their computer is.
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 10:25 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 21:10 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Total Newbie -- Best/cheap way to rewrite a Region 2 DVD to Region 1
By jteselle in forum Newbie / General discussionsReplies: 6Last Post: 3rd Nov 2009, 11:49 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58
