Im converting an AVI to MPEG so i can author and then eventually write to a dvd..
Im using AVI2SVCD to make the conversion. the probem that Im having is when I compare the original avi file to the newly converted file which is now Mpeg it is stretched a little wider and narrower with black borders on the top and bottom. This seems to distort the picture a little.
Are there any settings I could change to retain the shape like the avi.
Settings are as follows
AVI to SVCD or VCD
aspect ration is:4:3 no borders
CVD 352x480/576
Bicubic resize
Any help please
Razz
Results 1 to 13 of 13
What is the resolution of your original AVI? Have you burned the mpeg to disc yet and watched it on your TV? It might stretch to the correct aspect ration once you play it on TV.
Just figure out how long the movie is, and set your bitrate to fill up the disk. It can be as big or small as you want.
Did you play it on your TV yet?Originally Posted by razzcal
No I havent burned them yet as I still have to author them ...
I have played them through the computer and they looked distorted... -
That doesn't necessarily mean they won't play correctly on a DVD player.
TeeGee420 ..I burned the compliation to a DVD but it still looks squished.....any suggestions
Sounds like your video needs letterboxing. There is a way to do this with AVI2SVCD but unfortunately I'm not the person to ask. I normally use TMPGEnc for that conversion. If you were using that program I would advise that you change the arrange method(the advanced tab on the settings menu) to "Full Screen: keep aspect ratio". Sorry I couldn't be of more help.
DV-> AVI conversion
By bodomalo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 28th Dec 2010, 22:06 -
avi conversion
By joecass in forum Newbie / General discussionsReplies: 11Last Post: 11th Aug 2010, 15:11 -
TP to AVI conversion
By nic3 in forum Video ConversionReplies: 0Last Post: 20th Nov 2009, 18:04 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 07:04 -
mpg to avi conversion
By rwagar in forum Video ConversionReplies: 1Last Post: 27th Mar 2008, 23:27
