i have a mov file, from which i want to get one frame as a jpeg, how can i do it?
thamk's
Results 1 to 11 of 11
i downloaded the trial version, but for some reason it doesn't capture.
is there another programe that could do it? -
Can you play it with anything at all.?
If so you could pause the movie and do a screen capture -
Make sure "capture to folder" is selected in the settings not "capture to clipboard"downloaded the trial version, but for some reason it doesn't capture.
i tried both ways, i even tried capture to wallpaper, but it didn't work, my walpaper just became blue, no pic.
heres a way to do it without a capture button, play the movie full screen in what ever player, press "print screen" on ur keyboard then open a blank paint file press "ctrl + V" and hit "save as"
Visit My Blog ----
Tea Time Rants of an Under-Stimulated Student
http://teatimerant.blogspot.com/
Thanks!!! -
i dont think that always works. i tried it before and just came up with a black screen in paint.
works for me
Visit My Blog ----
Thanks!!! -
Apparently screen capture doesn't work if the picture is in
the overlay
HOWTO: Edit Motion JPEG (MJPG) in Adobe or even Windows Movie Maker
By rallymax in forum EditingReplies: 53Last Post: 25th Jan 2012, 21:23 -
If you rip just the main movie and AC5.1 track, do you lose pic quality?
By Tom80112 in forum DVD RippingReplies: 2Last Post: 15th Feb 2010, 13:26 -
Win Movie Maker jpeg quality
By The_Forastero in forum EditingReplies: 2Last Post: 19th May 2009, 13:35 -
Movie split on to 2 DVDs - make 1 movie.
By mattstan in forum EditingReplies: 3Last Post: 24th Oct 2008, 11:54 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 03:55
