OK, I'm tryiong to follow the excellent guides on this site to add chapters to my Mpeg using VCDEasy.
I can do that no problem, but I can't then go onto burn to VCD.
When I try to add chapters all I get is an XML file and I'm completely lost as to what to do next. On VCDEasy I cannot select the option of 'burn' as it says there's "no CD reader/writer found or ASPI problems"
I've tried updating my ASPI but still no burn option available.
Any advice?
Ok, I've now got a different problem.
I can burn some MPEGs now but quite a few of them are coming up with the error
invalid mpeg packet found at packet# 258858 -- please fix this mpeg file!
I created the MPEG by converting a cue/bin file using VCDgear 355 and ticked the 'fix mpeg errors box' but I can't seem to get rid of this error and burn the disk -
i dont what to tell you about the second problem, but the first, you might need to go file->setting and make sure you have the right burner selected. if not then it will say that you dont have one installed. also, when you click "file" make sure you have "expert mode" checked.
BDMV to MKV - Chapters Lost
By maxalfreeman in forum Blu-ray RippingReplies: 0Last Post: 25th Jun 2011, 19:56 -
Help with MKVMerge GUI creating chapters I AM LOST =(
By thumpy in forum Video ConversionReplies: 3Last Post: 14th Jan 2011, 07:59 -
Add chapters (at least) to already made DVD
By tge101 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 13:16 -
Need to add chapters to a 3GP file
By fredsp in forum Video ConversionReplies: 4Last Post: 22nd May 2008, 03:22
