i just got done encoding part one of training day, it is 595 megs, which means the second part would be about the same seeing how they are about the same size, is there any way to fit these both on ONE 80 MINUTE CD? or is it just not possible do ALL FULL LENGTH movies have to be put on 2 cds is that just a set back or am i doing something wrong?!? PLEASEEEEEEEE HELP!!
An 80min CDR will hold up to 800MB of data, so there's NO way to get two 565MB files on it, sorry. I don't know what settings you are using, but for the VCD standard 1min=10MB, ie. 74min CDR holds 74min and 80min CDR holds 80min.
You can lower the bitrate to get more file on each CDR, but at lower quaility.
OR raise the bitrate for higher quaility, but have less video per disc.
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
Portable Scanner by VuPoint: how do i make scans fit 8x11 letter size ?
By vhelp in forum ComputerReplies: 4Last Post: 6th Jun 2010, 16:37 -
Remove certain parts from MPEG-2 [no transcoding]?
By therock003 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2010, 13:49 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
Mpeg files wont fit onto one DVD
By jayman34 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 02:43
