  1. Folks,
    I converted some of the home videos and with menus it came to 9GB.
    Is there anyway that i can fit this onto single DVD???
    If its not possible, How can I burn onto 2 DVDs with the menus.
    I already created VOBs with menus.
    I used TMPGEnc DVD Author for creating menus.
    IS there any way if I burn this onto 2 dvds, what happens to Menus??
    How can I burn this using DVD author onto 2 DVDs?
    TIA,
  2. I tried DVD Shrik which compresses to 6GB.
    Still big tho to single DVD
    what other options Iam left with??
  3. what kind of audio are you using?
    if you're using pcm, try converting to ac3
  4. after u dvdshrinked them, load the new files into shrink again, and compress again....
    it's like dvdshrinking twice
  5. DVD2ONE lets you choose the size you want to compress your files to. I'd suggest you give this a try. Works for me.
    regards
    Malcs
    what comes around goes around
