i encoded an avi to a vcd using the vcd template in TMPGenc then i converted it to a dat file using vcdgear from vcdhelp.com, the video looks fine on my computer, but when i record it to vhs its all messed up, in the begining it looks like the tracking is off, lines at the bottom, and the audio is not synced, there like a big gap between the person talking and hearing them talk. everything is messed up.
try another VCR i had a problem like that some time it work's to change the VCR but not all the time
Here's a little suggestion. If you have a DVD player and if you have a CD writer on your computer, you could make a VCD and play it on you DVD player and record it directly to VHS tape (via a VCR, of course). I've done this before and it actually helps reduce some of the digital artifacts found on the highly compressed MPEG-1 used for VCD.
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 11:50 -
Please help! Problem with using TBC to capture VHS tapes.
By jrodefeld in forum Capturing and VCRReplies: 9Last Post: 9th Jun 2011, 18:08 -
Very strange VHS to PC capture problem
By fredhoward in forum Capturing and VCRReplies: 45Last Post: 9th Feb 2010, 09:30 -
VHS Capture Problem
By sdculp in forum Newbie / General discussionsReplies: 7Last Post: 15th Nov 2008, 09:58 -
Dazzle dvd recorder capture card and a VCR problem
By leeh in forum Capturing and VCRReplies: 5Last Post: 3rd Jul 2008, 14:53
