I've got a weird problem, and I don't think anyone else has it. When Sizzle starts up, no windows come up. I pick File>New and nothing happens. I get the following message in the terminal:
===== Sat Jan 17 2004 ===== 21:07:36 Canada/Mountain =====
2004-01-17 21:07:52.307 Sizzle[561] *** -[NSPlaceholderDictionary initWithObjects:forKeys:]: number of objects (1) not equal to number of keys (2)
I don't know if that helps. For reference, I'm running OS X 10.3.2 on a new 15" Powerbook 1.25Ghz w/ 512MB of RAM. I did a complete reformat after I got the Powerbook so there shouldn't be any leftover 10.2 crap messing things up. Oh, and Sizzle runs flawlessly on my G4 400 Desktop, but pretty damn slow.
Results 1 to 12 of 12
If it isn't broken, take it apart and find out why.
blog: deadsierra -
Actually, no. Does that do something?
blog: deadsierra -
I suggest sending Henry an email.
You can get his contact info here -
Now that I'm thinking about it, there is a chance that I might have used a theme or two in the past (I planned to once, but I don't remember getting around to doing it), so is there anything I should try?Originally Posted by llee782If it isn't broken, take it apart and find out why.
blog: deadsierra -
You would need to know what theme(s) you installed so you could examine the file lists included with them to see what files were replaced, then replace them with clean 10.3.2 versions. You might have some success by installing Duality GT and using its included Aqua restore option. I did have the same problem as you at one time, that is, that Sizzle was the only app I was aware of that wouldn't open a window on my system, but I was working on updating my own theme for Panther, so I knew exactly which files I had replaced. (BTW, I never released a version of my theme which would cause that problem.) You could check ResExcellence for themes created for 10.3.2 that come in .dlta format so you can easily see which files are commonly replaced. I don't think you would need to worry about any theme applied with ShapeShifter, because it intercepts processes instead of replacing files, and the current version doesn't affect very many files anyway.
llee782, thanks. A reinstall of panther, and sizzle is good to go.
blog: deadsierra -
I didn't realize sizzle was this cool. Damn fine application.
blog: deadsierra -
Ahhhh, I finally figured this out. It depends on Internet Explorer, and Arial Black (in MyDocument.m specifically). If you change it in the source to "Helvetica" in both places, it will work.
If you take just the Arial fonts and drop them into /Library/Fonts it works as well. Maybe this could be changed in the source to use a non-Microsoft font in the future. -
Wow, thanks for finding that! I've updated the page with a link to an Arial Black download. 8)Originally Posted by anaxamander
Computer failing?
By dylz in forum ComputerReplies: 11Last Post: 13th Mar 2011, 05:08 -
Failing to get 16:9 display!
By osmancik83 in forum Newbie / General discussionsReplies: 1Last Post: 27th Nov 2010, 19:46 -
Failing burner?
By Constant Gardener in forum DVD & Blu-ray WritersReplies: 2Last Post: 3rd May 2010, 13:57 -
is my cpu failing
By lordhutt in forum ComputerReplies: 12Last Post: 19th Dec 2009, 21:11 -
mkvextract failing
By Paratoxic in forum Video ConversionReplies: 2Last Post: 28th Nov 2009, 18:08
