Folks,
I created one Home DVD with menus using DVD author.
I want to preview it before burning onto DVD.
There is no option in DVD AUthor to preview and only it shows to burn onto HDD as vobs![]()
Can anyone help me?
TIA
Click on 'Create Menu', then click on 'Display Menu Settings'. Double click on #1 and you can preview.
I use 'ifoedit' (a free tool) to open the 'VIDEO_TS' directory and then use the 'DVD Play' option to check that menus and chapters function as intended, and also check that audio is in sync. If all's well, I then get 'ifoedit' to make a DVD image file and that's what I burn to disk.
A big shortcoming of TMPGEnc DVD Author is that it doesn't have a preview function. At least not that I'm aware of. You can use preview in DVD Workshop and DVD Architect. DVD Lab allows you to navigate the menu buttons and that's it. With DVD Author you have to compile the DVD and use Power DVD to see what your menus look like, or what happens if you click on a button.
What BobK is suggesting would allow you to see each one of the clips but not the menus. What JohnsO is suggesting is what I'm talking about. You have to have to wait to have the DVD compiled, before you can open the DVD files and watch in Power DVD.
But the other two sw that I mentioned have preview function cost a lot more money. TMPGEncDVD Architect is already giving us a lot of value for the money. I love the motion buttons and motion background features. I hope they would add the preview feature soon.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
TMPGEnc DVD Author 3
By WHISPERS1944 in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2008, 04:56 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
