Hello Gang,
I've managed to rip all of the ifo and vob files from a dvd using dvd shrink, however when I try and burn it using roxio 6 it tells me that the audio is ac3 or something of that nature, and if I choose to continue to burn the project that the audio will then be replaced with silence. Has anyone else had this problem? If so what Can I do to fix it.
Results 1 to 10 of 10
Is Roxio any good for data DVD-Rs, I tried RecordNow DX but some of the discs won't read in other DVD-ROMs.
Originally Posted by matthewmalay
Nero Express is also good for making data disks with DVDs.
I use Roxio EZCD 6 mostly for making Music CDs.
and Mp3 music CDs for my Pioneer CD Player. -
I use Roxio to make all my DVD backups, works just fine (better than Nero on my system, Nero always said every disc was illegal).
Open up "Creator Classic", select a new data dvd as your project. Create the folders AUDIO_TS and VIDEO_TS, or drag those folders over if dvdshrink already created them.
Name your DVD, hit the burn button... and there you go, it's done. This is how I do all of mine. -
Roxio isn't very good at all as a DVD app. its okay for data, but for movies don't bother. Last I checked it still didn't burn the correct UDF format to be compliant on all players. Easiest free way is use IMGTools Classic to make an ISO from your VIDEO_TS folder and burn the ISO with DVD Decryptor.
i put a dvd 9 in my drive and ripped it with dvd decrypter now i want to burn it and im going to be using nero 6 so i select dvd and than do i just put all the files it ripped onto nero? like someone was saying sumtin about some audio_ts and video_ts folders have to be on the cd? well where are they? or what do i do with them?
if you could explain to me it would be awesome. -
open up creator classic
click "data cd" under project window
Rigth click, create new folder, name one AUDIO_TS and another VIDEO_TS.
bring in all the files that you ripped to your hard drive and place them ALL under the VIDEO_TS folder.
name your DVD anything you want.
click burn.
I have used Roxio to create all of my backups, havent been let down since. They all play on xbox and my standalones just fine. -
When Roxio first came out with Version 6 of EZCD ... it didn't support making Copies of DVD5.
Even tho it had a DVD Builder Program it wouldn't let you use ... Classic ... to just burn the folders ... VIDEO_TS and AUDIO_TS
But a few months ago ... they came out with a upgrade version ... not sure if it was version 6.1 or 6.2 ... but now it will do it ... so they say.
And since someone a few postings up ... is doing it ... yep it works now.
I tried making DVDs ... when I first got ... Roxio Easy CD and DVD Creator 6 by doing that ... and they were lemons.
So ... I found Nero ... and I've never used Roxio's method.
Reason ... well ... why should I ... Nero works just fine. And I know it will work ... and not make a coaster. -
Is there some trick to getting Easy CD Creator to burn a DVD from VIDEO_TS and AUDIO_TS folders and files created in another application?
I'm using DVD-lab to take home movies (rendered as DVD-compliant MPEGs), author a DVD, and write the DVD content to my hard drive. I can sometimes use DVD-lab to burn the DVD, too, but that doesn't seem to work with all media types. (Specifically, it doesn't work with DVD-Rs; I tried two different brands . . . I'm in the process of posting to the DVD-lab message boards to find a solution to this, but if anyone watching this topic can answer that one, too, that'd be great.)
I tried just taking the VIDEO_TS and AUDIO_TS folders and files and burning them to a DVD+RW with Easy CD Creator (just as a data disk), but the DVD would only play on my PC with PowerDVD; it would not play on my standalone player (a Sony 735S, I'm pretty sure; I'm at work right now, and can't double-check . . .).
Is there some trick to using Easy CD Creator to burn DVD content created in another application? Please help!
Thanks!
-Dave
Roxio Media Creator Suite 10 Stange Results
By DB83 in forum Authoring (DVD)Replies: 7Last Post: 16th Dec 2011, 12:53 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 12:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 15:27 -
Problem with Roxio Media Creator 9 and slideshow
By ingeborgdot in forum Authoring (DVD)Replies: 12Last Post: 30th May 2007, 11:58
