  1. I would like to edit out parts of my program which is in dvd-ram .vro format. Is there any program that can do this. All I want is just to cut out parts and save it back to .vro without any degrade in quality.
  2. Member lacywest's Avatar
    Aug 2001
    California
    Womble mpeg-vcr ... Works great ... very precise for removing commercials
    TMPGEnc DVD Author ... but not as accurate
    Dec 2001
    No. Calif.
    Do these programs actually save in VRO format?
  4. Womble is way cool and very easy to work with
    thx
  5. what should type of mpeg should I save it as when in womble? Will there be any quality decrease from the origional?
  6. Member lacywest's Avatar
    Aug 2001
    California
    Does not re-encode ... makes a copy.
    When I save the edited vro video ... I use the extension ... "mpg"
