When I try to capture AVI using VirtualDub my screen turns black with a green stripe and then completely locks up my computer! (Like the board crashed or something!)
Does anybody know how to get VirtualDub to work? I want to enventually capture TV to uncompressed huffy codec.
I already downloaded and installed DX8 and the Capture Update, as well as the latest driver and software from ATI's website. Oh yeah, and I installed the wrapper ini.
Maybe someone who has a TV Wonder can tell me how they set it up.
My system specs:
Windows ME
Athlon 800mhz (Slot A)
Crucial 384MB pc133 RAM
Asus K7V Motherboard
MSI Geforce 2 gts 32mb ddr
IBM 15 GB 7200 rpm ata/66 & WD 60GB 7200 ata/66
OK! i am running WinME. everytime i try to use Vdub i get the error message for no device drivers(VFW). what is the wrapper ini? is that what it takes to capture useing Vdub on WinME? if i can get past the error message maybe i can figure more out......
The wrapper zip file is located here:
http://faq.arstechnica.com/?i=4
Once you are at this site goto the "Capture Card Drivers" section and download "New WDM -> VfW driver wrapper".
This has the wrapper ini file (once you unzip) that will stop that "no device driver(VFW)" message. Just right-click the ini file and select install.
Now VDub will start but this is as far as I have gotten.
Hope this helps! (SOTN rocks!!!)
ATI all in wonder help
By bobo666 in forum Capturing and VCRReplies: 1Last Post: 16th Aug 2010, 17:53 -
ATi TV Wonder VE not working...
By kkpatel87 in forum Capturing and VCRReplies: 0Last Post: 2nd Aug 2009, 00:27 -
ati tv wonder pro
By rcomp in forum Capturing and VCRReplies: 0Last Post: 26th Mar 2009, 23:14 -
ATI AVIVO
By therock003 in forum Capturing and VCRReplies: 18Last Post: 28th Jan 2009, 19:31 -
ATI 7500 All in One Wonder
By justmehere in forum Capturing and VCRReplies: 3Last Post: 8th Feb 2008, 16:08
