I recently put a new computer together with an on board sound card (Realtek AC97 Audio). Since day one I've been getting a fair amount of hissing/crackling on the line out. It's not too bad on speakers but pretty annoying on headphones. To give you an idea its sounds like an electrical whirring sound (the HDs?) coming through to the speakers / headphones when there's no music playing or playing at a low volume.
Any advice would be appreciated.
DF
What is connected to your computer? It sounds to me that you have a ground loop problem that is probably related to video capture. Do you have a cable or antenna connected to your PC. If you do, you will need to get some kind of isolation.
Triphop -
It may be noise from the cpu fan. Try a different one. I had that problem before.
Just a regular PCI TV card with a coaxial antenna cable connected, but it makes the same noise regardless of whether the cable is connected or not. You think it still might be picking up signals anyway? The problem is that the sound isnt erratic, (i.e. like random tv signals) its more of a constant hum.Originally Posted by triphop
DF -
Makes sense, i'll give it a try. Thanks to everyone for the help.Originally Posted by bugande
DF -
It may be a faulty chip. Is it on all inputs? Does it depends on the volume? On which input?
No, just on the line out as far as I can tell. The computer I built has two line outs, one from the back and one from the front of the case but you can hear it from both bc basically its the same jack.Originally Posted by W_Eagle
Thing is, you can't actually hear the crackling if you have music playing, but if you mute the volume or turn it down very low (or if the song has a low volume intro) you can hear it very distinctly on the headphones. That's actually how I noticed it, by putting on the headphones for the first time.
DF
Noise instead of sound
By Nor in forum ComputerReplies: 5Last Post: 21st Oct 2010, 12:20 -
Getting rid of crackling noise
By adamf154 in forum AudioReplies: 1Last Post: 14th May 2010, 07:40 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
How do I overclock Intel 945G on-board video card?
By oleglelchuk in forum Newbie / General discussionsReplies: 10Last Post: 13th May 2008, 21:48 -
on board sound card
By m baqar in forum Authoring (VCD/SVCD)Replies: 2Last Post: 26th Mar 2008, 22:26
