can someone suggest a good and easy to use mp3 ripper program so that I can extract music from my dvd's?
I have besweet and can't fathom it out at all so any directions with this would help also, otherwise I need a bog standard ripper that does the tracks to mp3 and nothing else.
help is really appreciated.
Indeed, I was just thinking of my home authored DVDs which all use MP2 audio as the PAL DVD spec supports it.
Hi,
What I like to do is use software called mp3DirectCut, which is freeware also. It will record in mp3 format and you are also able to chose the bitrate and so on. It will also edit the mp3's a little. -
CDex will take it directly from your cd and into mp3 (or ogg vorbis, or wma, or jesus there are a lot of options on it).
it can also reencode a compressed audio track into another format (a la wma -> mp3)
in my eyes, CDex is the best program out there for basic music stuff.
but if you are taking it from a DVD, you need to do what was stated above.
Creative MediaSource: Ripping CD to MP3?
By Startropic1 in forum AudioReplies: 1Last Post: 23rd Feb 2011, 11:43 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
Ripping mp3 from DVD?
By t_jay17 in forum AudioReplies: 4Last Post: 16th Dec 2008, 14:50 -
Ripping MP3 from Cell Phone
By Vance in forum AudioReplies: 0Last Post: 21st Jul 2008, 13:34
