is there any way to put one full movie on a 700 MB writable?or do they have to be seperated on to two differenty disc
It all depends on the lenght of thew movie you're talking about and the kind of quality you want to achive.
For a "regular" movie in VCD format, you might be able to get away with it. If you want to do SVCD you'll most likely want to go for 2 CD's.
Again it all depends on what kind of quality picture you want and/or expect. If this isn't enough of an answer you might want to add what kind of quality you're looking for, ie; doesn't matter (just 1 CD), decent, good, almost DVD, etc. -
Decent quaility is a matter of opinion. The VCD standard allows 74min on a 74min CDR and 80min on an 80min CDR. From a DVD rip you'll get better than VHS quaility. Now since most movies are 90~120min to fit the whole thing on 1 disc you have to lower the bitrate, this will reduce the quaility.
Since CDRs are so cheap I just put movies on two 80min CDRs. Normally ~1hr on each disc (that way I can increase the bitrate for better quaility.
For best results use TMPGencs 2pass VBR w/ motion search set to high; or CCEs multipass VBR (i normally use CCE 3pass VBR, above that is over kill).
If you're a complete newbie and worried about all the different settings give DVD2SVCD, DVDx, etc. a try. -
Well, IMOHO CCE is the way to go. If you need help check out the how-to's on this site.
If you're looking for good quality then you'll need to with at least 2 CD's (if over 2hrs. maybe 3).
A tip... no matter what you encode with, use FitCD. It's an excellent bitrate calculator.
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 12:36 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 22:25 -
Newbie question about learning
By Tundra Trout in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 17:41 -
Newbie question about cd music
By justalice in forum AudioReplies: 4Last Post: 7th Apr 2008, 19:08 -
Newbie Networking question
By karl333 in forum ComputerReplies: 1Last Post: 5th Mar 2008, 12:23
