Hello. I recently downloaded some subtitles but the file had a SUB file as well as an IDX file. I asked the creator and he said:
"idx short for index. and that sub file shouldn't be a normal one (normal as in you can't see the script if you open the file with an editor) if there is a idx file. Thats because those are images in the sub file and no text.
I'm not in the mood to explain right now why and I doubt you really want/need to know lets just shorten it up: you need both files and both files need to be labeled the same as the videofile to work properly."
So I want to add the subtitles to the video permanently and then to convert the AVI to MPEG for VCD. What should I do about the IDX files and what tutorial should I use? Currently, I'm looking at this one:
https://www.videohelp.com/srtsubsvirtual.htm
If I convert the SUB file to SRT via Subtool, what would happen to the IDX file? I'm not sure what the creator meant by "those are images in the sub file and no text" because my AVI file is still downloading. Any help is appreciated!
if you are converting with tmpgenc you can use vobsub(it supports the sub and idx subtitle formats),
https://www.videohelp.com/forum/userguides/153058.php -
But I still don't get it. If the SUB and IDX files are meant to be used together at the same time?
Weird Problem - Adding subs to avi doesn't work okey on DVD Player
By andreas.cro in forum Newbie / General discussionsReplies: 6Last Post: 1st Aug 2012, 12:29 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
adding subtitles
By dabud in forum Authoring (DVD)Replies: 3Last Post: 20th Oct 2009, 22:27 -
Adding subtitles
By tommcd64 in forum Authoring (DVD)Replies: 7Last Post: 28th Aug 2009, 00:39 -
DVP5982/37 subtitles weird experience
By brancaleone72 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Jan 2008, 16:40
