  1. Just read your "basic" guide for DVD Shrink, and I was just curious what program you use for the actual burning of the DVD? Also wanted to know if the program you are going to suggest for burning conflicts with Nero, and if you recommend that I delete Nero from my system? Once again, help greatly appreciated...
    Cheers,
    Joe
  2. If you want personal response, you should use PM.
  3. you can use nero, u can use RecordNow Max...
    i've been converting the output from dvdshrink into an ISO and then burning it with dvd decrypter... u can also use dvd decrypter in file mode i think and burn it without converting to ISO.
    i never had a problem with dvd decrypter but i heard CopyToDvd is a good burning program to use with dvdshrink so im gonna try that next.
