I need help in buying the best capturing device for my laptop. reason i say so is cause i just bought this monster laptop and i also just got an external DVD writer. now i have about a billion hours worth of The Simpsons episodes and i wannna convert them to DVD. WHat the best capture device for a laptop with Firewire and USB 2.0 ports? this laptop is new to the market so newer equipment is the best way to go. Any help?
while you're waiting on more replies, good time to search for such over in the capture cards (see l/h side of page). you can search for usb, firewire or pcmcia types.. and probably find related user comments.
Enjoy that new rig ! -
You might look into the ADVC-100. A little expensive, but it will work with most any firewire port and you can use it with other computers in the future. I have tried it with my laptop and it works great.
I use the Hauppauge WINTV PVR USB2.0 with my Dell Latitude.
I get very good results. I added a USB 2.0 dual port PCMCIA card.
The Hauppauge uses hardware encoding and produces DVD compliant mpeg files. -
Hauppauge makes great products, great software (namely, total control over your capture settings as opposed to other manufacturers), and seem to give a lot of priority to support.Originally Posted by grossjamesh
I just got the PVR-250 (PCI) after getting 4 different cards and comparing them. Couldn't be happier.
Looking for capture device, is this what I need?
By V Bot in forum Capturing and VCRReplies: 3Last Post: 21st Apr 2012, 10:16 -
Capture Device
By NMeade in forum Capturing and VCRReplies: 7Last Post: 24th Feb 2011, 18:23 -
1080p HD video editing and capture on Apple MacBookPro notebook?
By rjamesd05 in forum MacReplies: 19Last Post: 19th Sep 2009, 05:55 -
Capture desktop of another PC/notebook
By cardenal in forum Video Streaming DownloadingReplies: 1Last Post: 26th Jul 2009, 23:55 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31
