    Jan 2004
    Ok, first i used AVI2DVD (or SVCD2DVD) and converted my video and audio just like the tutorial said from doom9. ANyways i noticed that it took an EXTENSIVE amount of time to do so, about 18-20 hours for the complete conversion. So i started using a new app. Well to me it was a new app, it called Main Concept MPEG Encoder. With this app i can do a .avi to Mpeg conversion in like 2-3 hours MAX. but when i use the other app it takes really long. So i decided to start using this on for the speed, i dont have 18-20 hours to kill waiting for a movie to get encoded. Now here my question, when i used AVI2DVD (or SVCD2DVD) my .VOB files ended up at about 1.4 gigs or so. now when i used Main COncept the SAME exact file ended being bigger than the DVD+R size! so i decided to re-encode it using a downsampled audio. from 384 to 128 and the file size was just right. about 4.4 gigs or something of that nature. Now why does AVI2DVD (or SVCD2DVD) have a smaller file size? Just a question that was bugging me. that 4.4 gig files takes longer to burn by a few minutes but is more compatible that my other movies that i used AVI2DVD (or SVCD2DVD) on. ANy help?
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Filesize depends on two things, bitrate (in kilobits per second or kbps) and length of the video. Obviously using one method you used a higher bitrate than the other.
    Jan 2004
    In which generally gives better looking video, yes?
  4. Member teegee420's Avatar
    Dec 2003
    Southern California
    Assuming you have a good source, a higher bitrate will produce nicer looking movie. However if your source isn't too great, a lower bitrate and resolution would be more sensible.
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Up to a point....beyond which you won't notice much difference. What that point is depends on the the source, the resolution, how fussy you are etc. See teeegee's comments above.
