Is there a way i can run more than one TMPGenc? I want to convert more than one video at a time. Thanks in advance
i suppose you could. i dont know how to do it. but you do know, that if you are converting 2 videos at one time, it will take twice as long
Yes you can but it is not the best way. It's better to use the batch encode feature and do one project after the other. Encoding is CPU intensive (almost 100% usage) so if you do two projects at once it can take more than twice as long. With batch encode you can save your settings and encode at a later time as well, i do mine overnight. Hope that helps.
"Art is making something out of nothing and selling it." - Frank Zappa -
100%...you sure...cuase i useally do multiple things when i encode and i have no problem...
i only have 900mhz amd anthlon and 384 mb ram... -
Doubt it. One session running (encoding) usually uses all available CPU resources. running another encode at the same time would at best split the
CPU resource and extend processing time accordingly.
(edit add) Saw your post on "running other things" and yup, that's possible to do - but your other activities just "steal" CPU resources away which just makes the encoding take longer. -
Originally Posted by The14thGOD"Art is making something out of nothing and selling it." - Frank Zappa
Running 2 in parallel can easily be more than twice as
slow, compared to sequentially. The reason is that just
one doesn't have to seek the disk heads, especially
if the input and output are on different drives.
If you have to do it , set the priority of one very high and the
other very low.
Why do I have multiple files when I convert HD to SD using Tmpgenc??
By Endoking01 in forum Newbie / General discussionsReplies: 12Last Post: 9th Jun 2010, 21:43 -
Multiple instances of tmpgenc?
By Bully9 in forum Video ConversionReplies: 1Last Post: 25th Aug 2008, 21:14 -
problems with avc to mpeg-2 in tmpgenc xpress 4.0 - more than 3x run time?
By NoFace in forum Video ConversionReplies: 3Last Post: 18th May 2008, 21:01 -
DVD is different filesize when I run it through TMPGEnc
By Salva Veritate in forum Authoring (DVD)Replies: 5Last Post: 17th Dec 2007, 18:10 -
Simple Menu but movie won't run - TMPGEnc DVD Author 3
By gayclarke in forum Authoring (DVD)Replies: 6Last Post: 14th Sep 2007, 09:00
